i've dabbled in grinding my own blades and forging a couple from 5160 steel. i understand the principle of heat treating and tempering. i bought a sub $300 sword made from 5160 steel. the reviews were quite impressive. when i tested the blade by chopping twice on a pine 2x2, it bent. the file test failed and also flexing the edge test failed. this leads me to believe the blade was either not heat treated correctly or shaped in the annealed state and not heat treated at all. people on a forum said i could re-temper the blade by putting it in on oven at 250 deg and quenching it in water. i don't think this will help. my thoughts are the blade needs to be heat treated and tempered correctly. what are your thoughts?
