- Mar 2, 2006
Hi, All: I've made Wayne Goddard's "One Brick Forge". I took an old Nicholson bastard file, annealed it and removed stock to shape the blade. I put it in the one brick forge and used a mapp gas burner to bring up the heat.
For those of you familiar with this forge, there is a "fire-hole" for the burner nozzle. The remainder of the forge is a 1" x 1.5" hole going through the brick from end to end.
Once I heated the blade to orange, I pulled it out and quenched it in corn oil. I tested the blade with a file. The blade is 4" long. From the tip back for 1.5", the file would not scratch the blade. Hard as a rock. From that point to the ricasso area, the file did cut. That area did not harden. From the ricasso to the butt of the handle, the file would not cut. That was hard. In other words, only the area that had been in direct contact with the flame from the burner was soft. This area also showed significant carbon runs. Have I overheated the blade in this area?
What can I do to equalize the heat and achieve hardness in this area? I thought it might be advisable to place a baffle of some sort between the flame and the blade. I could probably buy some ss foil and wrap the blade to prevent the carbon run but don't want to invest in it.
If anyone has some suggestions, please let me know.
Thanks!
Thanks!
