One Handed Firestarting
After reading though the thread on the best emergency firestarting method in a "tipped Canoe" senario, and reading some of the comments about starting a fire with one hand, I thought I would post this. Back when carrying a handgun was a job requirement (as opposed to an obsession :D ), I recall several injured hand exercises that we had to go through. I think this is a good practice with survival skills as well.
I got this from the late Gene Ward, who demonstrates this technique oon his DVD, Survival: Beyond the Ten Essentials. Gene held that this method is actually easier that the normal two handed method, and was great for teaching children.
Starting a fire using a ferro rod is very easy to do with one hand, provided you have a saw, or your hacksaw scraper still has its teeth.
First, as in all proper firestarting, gathering plenty of tinder, kindling, and wood is essential, so you don't have to run around franticly after you get fire. (Not that presonally know anything about that! :o) Make sure you have the kindling and fuel separated into various piles by thickness and located within easy reach of your good hand.
Second, find a flat piece of wood to use as your fire base.
Third, use your saw, or the saw teeth on your scraper (striker) to cut a slot in your fire base. This slot should be cut to a depth of about half the width of your scraper.
Fourth, place your scraper in the slot and scrape a pile of tinder (magnesium, fatwood, whatever) by scraping it against the scraper in one direction. Scoop the scrapings into a pile close to the scraper.
Fifth, scrape the ferro rod across the embedded scraper so that it will rain sparks down on your pile of tinder.
Sixth, once you have your tinder lit, add kindling of increasing sizes until the fire is big enough to add fuel wood.
-- FLIX
I've done the method that FLIX describes, and it works well. As ashtxsniper said, blastmatches are another option. A SparkLite is another good one-handed option.
A blast match is easy to use one handed.
I'm a bit of a noob, and hadn't heard of a blast match until you mentioned it. Very intersting device. How long will a blast match it last? I know that the ferro rods last for a VERY long time.
The blast match is a ferro rod with a spring loaded striker built around it. It last a long time as the ferro rod inside of it is around 7/16" thick.
There are lots of one handed methods of starting a fire. These include everything from striking a match off the heel of your boot or flicking your Bic, to purpose build firestarters like the Blast Match, Strike Force, or the little Spark Lite. I have all three, and have carried each at different times. The Blast Match and Strike Force are HUGE and the Spark Lite can be pretty finnicky as to which tinders it will light. On the plus side, the Spark Lite is nice and small.
My purpose in starting this thread is not just to promote "my way", but rather to encourage people to practice with whatever firestarted they are currently carrying, or to evaluate it in light of one handed use.
-- FLIX
What I do is take a piece of wood, flat preferably, but any old stick will work, gouge a small shallow hole in it, just big enough to fit the tip of my firesteel. Then put the tip of the steel in it, and use my foot to hold it at an angle. Place your tinder and scrape away.
Tried this a second ago with a cotton ball, and it took me about of 30 seconds to get a flame.
:thumbup:
-- FLIX
Definitely a good thread :thumbup:
:thumbup:
I do something very similar, except I never thought of reaming a hole into the wood to get a better strike. I will have to do that from now one. Thanks.
:thumbup:
Nice alternate method!
Another "one hander" would be to hold a piece of a PCB near the wheel of a used up Bic or Zippo, and run the wheel down your pants, throwing the spark onto the PCB, which you could then place under your fire lay.
-- FLIX
* steel wool and a 9 volt battery.
* Putting the matchbox in your mouth and strike. Just remember to inhale before so you can exhale the fumes away through your nose, I learnt that the hard way :(
* Most chemical solutions can be used with one hand.
I have to try the firesteel á la foot some day.
The way I teach one handed fire steel striking is to step on the steel with it laying flat. If you need to make a fire fast, you might not have time to make a notch for it. This would be a good way to light a fire if you had time to spare but the easiest and quickest one-handed way is to simply lay it flat, step on it and strike sideways.
On a side note, the reason I have a lanyard on my firesteel is for this very purpose!
Kev
Kev
How I have done it.
Granted I do have a little use (10-15%) of my left arm/hand, this way just holds the fire steel more securely. The notch idea is a nice thought too.
Hey Guys..
Flix..
This is a Very interesting topic.....
A topic that needs to be discussed, and something I think Everyone can learn from...
A hand injury is a VERY real possibility in the woods...You'd better know hw to do it,, thats for sure...
ttyle
Eric
O/ST
I know I never thought about this being that important until now. I have injuried my hand more than enough times and I still used it anyway. It hurt like hell, but I got done what I needed to.
This is a great thread!
For a real challange practice using your weak hand. More than likely it is your strong hand that is injured. Since I am right handed I have been training myself to use my left hand for basic tasks.
I have been doing the same thing. That is one of the reasons I really like the Peter Kummerfeldt video and book. It doesn't have all the information about how to build a firebow, get water using a solar still, etc... What it has is techniques that can be performed even if you are injured and have the use of only one arm. The equipment he chooses is based on its abilty to be used when the conditions are horrible and you are injured.
When I saw him speak at the Dallas Safari Club show last January it was right around freezing outside and alternating between snow, sleet and freezing rain. It was about as bad a winter storm as I can ever remember hitting Dallas. We were inside, warm as can be, and he was lecturing and demonstrating about the benefits of metal matches, PJ cotton balls, trash bag shelters, etc... He kept saying he should move the class outside and tie our strong arms behind our backs and then have us try and do what he was lecturing about. His reasoning was that in a survival situation we were more than likely going to be cold, hurt and in the elements as opposed to warm and dry and a 72 degree room.
