- Dec 18, 2009
I saved this from the trash heap about 3 years ago at a job I worked at. Guy was just tossing it because it has some cracks in it. Told him I don't know what I will use it for but I am sure it will come in handy some day. Yesterday it came to me, a vise. Not super heavy duty but better than my hand. I am actually thinking of making a reproduction of it in a much heavier duty model. The ways it could be used are endless and the types of jaws one could make are endless also. One of the things I thought it would be real good for is mounting it to a drill press table thus making a make shift mill type table.
If I do remake it I would make the design about the same, both ends would move and be lockable. I would change the way it locks, get rid of the round locks you see at either end of it with the set screws, and just put the set screws in the slides. I'd put 2 or 3 set screws so I would not have to scar the ways from having to torque 1 screw so hard to keep it from moving. I would make it out of steel, not cast. I would make the slides much stronger and longer, as short as they are they will round out the holes and create a tipping of the jaws. The potential of this little thing is huge as I see it, a stronger base and you could replace most vises. I'd improve the threaded rod, make it bigger and put it through thicker metal so it would never strip.
I still need to clean this one up, paint the jaws I slapped together and get some soft inserts I can mount to the jaws so I do not scratch my blade. That is my 1st knife in the pics, will post better ones when I am done in a different thread probably.
The blots are loose and the blade is just sitting there so not to scratch it.
Holds a knife well to glue on handles.
