dialton
- Jan 1, 2007
UJ Rides again.
If you don't have the itch, don't scratch. The first plunge is the start of a long addiction. Run..................
UJ Rides again.
:thumbup:I want mine in satin/blackpaper.... then a double cut ;-)
Judging by the pic posted and the stated 3.5" blade, the handle of the SAR3 should be 4.25" with an OAL of 7.75". I really like the design and specs on this one.
Uncle Jarvis, is that you?![]()
buh-bye![]()
Could we have a pict with SAR 8, 4 and 3 on it?
If the spine was square for firesteel scraping, it'd be perfect. I wonder if they'll do a one-off...
Scrape with the jimping thingimabobs. They certainly are sharp enough.
If they are sharp, then this might work.Scrape with the jimping thingimabobs. They certainly are sharp enough.
It really messes up the edge. If this is a SAR blade, I'm assuming it's wilderness oriented, and firesteels are my primary source when I'm backpacking. They often work for me where other methods fail. A nice square spine also helps in making kindling, I often use it for scraping to save the edge.Why would scraping with the blade be a bad thing? How many times do you start a fire with a steel? It shouldn't be your primary fire source.
This is a good looking knife, but like my SAR 5, I'd probably take a section of the spine to a belt grinder and square it off.
