I would think as long as you aren't hitting the lanyard tube, you should be insulated.Does anyone know if RES-C is grounded?
Meaning you can cut into a live wire safely. Whether by accident or intentionally?
Whatever you do, please please record it if you try it! I think it could possibly be awesome and do that viral thing everyone loves if it goes just rightDoes anyone know if RES-C is grounded?
As was pointed out, the brass tube does contact the tang of the knife and should prove very effective in transporting enough juice to your hand to blow your socks off!!!![]()
Nice knowin' ya Skunk. . . . . let me know how your test runs for you!!!
Jerry
I was thinking of using plasti-dip.I have often wondered the same thing about Micarta handles since micarta is used as an electrical insulator in some applications.
Everything is a conductor. Question is how good or poor it is. Like you said about your axe, most insulated tools I have used like a screwdriver, have maybe a thin 1/16 coating around some parts of the tool, and are rated in the thousands of volts.
Not telling anyone to try it, but rubber is usually a poor conductor so I would think with res-c cover the brass tube with electrical tape and you would be good.
That would work.I
Was thinking of using plasti-dip.
If it is a factory uncoated blade, I guarantee you it will ground through the tube fastener.
If it is a coated blade, it still might, but there is a small chance that the coating could prevent it.
