The Avispa is an upgrade to the Rat. It is the design they said they originally wanted when designing the Rat.
I wouldn't call it an upgrade. I'd call it an option. I prefer the Rat 1 for blade shape and satin finish.
At their sub-$30 price points the good news is you can probably try both without much trouble. I prefer the RAT but to each their own. Some may think the Avispa framelock is tougher than the RAT liner lock but compare their thicknesses at the narrowest points and it's a non-issue. Both great knives!
Prefer the Esee Avispa. I preferr the Kephart style blade for outdoor use. Rides nice in the pocket as its a bit flatter than the Rat. Basically the same knife, but with the blade shape and being thinner, the Avispa comes out on top.
Nightflyer
Understood. I personally have never had either fail on me because I generally use fixed blades for hard use.I never understood why people who compare liner locks to framelocks use that as an argument, at the point of contact a frame lock has significantly more metal in contact with the tang of the blade, making slipping less likely. The liner locks have less metal contacting the tang and lock slip more likely.
If a frame lock and a liner lock share the same thickness at some point they might have the same loading failure.. for example placing the handle in a vice and applying weight to the spine of the blade until the liner or frame buckles.
Liner lock failures I've experienced haven't been from too much weight on the spine of the knife its from lock slip. Framelocks can have lock slip as well but with more metal contact I think its less prone all things equal such as lock geometry etc.. all this Is IMO.
