You sir are an idiot.
There are Mora's made out of stainless steel with thinner blades than an Opinel which are intended to handle light chopping.
-Cliff
if the knife is capable of doing it and I want to do it, by all means I'll do it
Which models are you refering to?
I think the picture showing the indentation from the ring lock clearly shows and improperly heat-treated blade, as the spine whack was by no means forceful.
A point I think has gone rather undetected in this thread as a whole.
I've never had a bad one, but i dont think they are good for chooping either!![]()
I have a no 12 and i cut stuff with it....i saw a thread on battoning with an opinel and it sead to work ok....I guess you got the one bad in a million....
Normally they are. This behaviour is an exception compared to my previous experience.
I think the picture showing the indentation from the ring lock clearly shows and improperly heat-treated blade, as the spine whack was by no means forceful. A point I think has gone rather undetected in this thread as a whole.
I'm going to go with DWM on this one , maybe people in different parts of the world use different tools , who knows..... In my extended family there are a lot of hunters , we fish we hunt he kill we clean and not one of us has ever used a flippin' axe/hatchet to skin game , man do I want to roll my eyes on this but i'll keep it nice![]()
Actually Normark knife company(usually made by Eriksson) use to make a skinning axe just a point of interest.
Until I came here I never once heard of the term "batoning" unless a girl wearing a cheerleader outfit was nearby , batoning may be the acceptable practice in some parts of the world but I will stick to my axe or better yet, pruning shears for kindling wood ( why in the world would you baton when you can prune).
Well unfortunately it is a technique that is highly over used now it is meant to be used as a way to cut larger pieces when you simply only have a knife but most people tend to use it now as a magic show trick or some kind of way to evaluate a blade not meant to chop with. as I have said before if you only had one match would you strike it then go build your fire why waste a valuable tool by doing what it is not inteneded for. batoning does not make you a knowledgeable knife user or a bushman for that matter knowing how to use common sense does. Your brain is your most valuable tool might as well use it.
Possibly or the fact that the blade is the largest one they could me that the stress placed on the area hade a greater effect.
I don't understand the controversy over Vivi's testing.
Seems to me a blade that fails in such a fashion against wood and it's own lockring would likely have very poor edge retention under "normal" usage.
[lock ring failure]
Yes it will be greater as the torque will scale with the length. However this doesn't mean the blade would fail, it will just push the lock bar right off the blade by impacting the wood.
How can you be certain of this they use Beech wood and have youtested it your self to know that a 100% of the time that is the common failor.
Impacting the spine to increase the ability to cut/split is fundamental to wood working. I have never heard it called batoning, but every carpenter is familiar with it as was discussed in detail on the Wilderness form the last time this was brought up.
I am a master craftsman when it comes to wood working I have given seminars at wood working shows throughout ontario and taught wood working classes in the U.S. A wood worker knows which blades to hit from behind and which ones you don't thats why they make chisels and I have never had to hit the spine of a plane blade.
http://www.bladeforums.com/forums/showpost.php?p=3912596&postcount=62
Lack of experience and baselines leading to unfounded conclusions of user abuse when there is obviously a case of a horrible blade which is apparently weaker than the metal locking ring.
Just because some one doesn't agree with you Cliff doesn't mean they are not experienced now, now I hope you are not reffering to me.
I think the major thing here is there are some blades you chop with and some you don't some you cut meat with and some you don't and some you carve wood with and some you don't the beauty of having so many edges to choose from is you get to buy so many. Yet again you should use them for what they are intended to do.
Abe
How can you be certain of this ...
There was another recent thread about batoning with an Opinel and while I respect other's rights to post a thread , I thought it was pretty silly to even consider such a task with a blade not meant for that task... An Opinel has a thin , fine blade far better suited for garden work or gutting fish , light carving or opening envelopes (my opinel performed these well) than to use it to build yourself a log cabin.
It's an Opinel, too light for chopping? Well, if it's too light, then how was enough force generated to damage the blade? Because it was a poor blade. It dented, rolled, and tore; doesn't seem suitably hardened.
Hardness check. Take your #10 and try and scratch the #12 with the 10's tip, then do the same to the #9. Then do the same thing but use the #12 to scratch the #10 and #9. I think that should show you if its a soft blade or not. The #9 and #10 are the same steel as the #12 right?.
Generally you also don't tend to impact draw knives, chip knives, scrapers, etc., but you do impact chisels, froes, hack knives, hatchets, etc. . There is also of course nothing inherently different from an impact on the spine of a blade to increase the cutting ability than simply pressing on the spine with the off hand or with the thumb to also augment the cutting ability. Both of them are achieving the exact same goal which is to provide more force to the blade and the number of applications are obviously very wide if the amount of force available is high, it basically is no different than just increasing the inherent cutting ability by the same amount. Cliff
