- Jun 28, 2019
When refinishing an opinel, do you just knock off the gloss from the old finish, or do you sand until the orange-ish stain fades to a plain wood color? Couldn't quite tell from past threads.
I appreciate the response, I'll likely reshape the end a bit now that you mention it. I've sanded it out enough that it's faded to a plain wood shade, now just to get the pivot pin removed and finish up before staining.While you are refinishing it, why not reshape the handle. If you thin the flared pommel, it will pocket better. Look around at some of the many Opinel threads.
I know this does not answer your question squarely, but it is something for you to coonsider.
If you want a dark color, I have been using a propane torch to scorch/ char the wood. After removing any finish, of course.
I saw this technique on a home remodeling show used on wood siding. It has some Japanese name. I have used it on walking sticks, tomahawk handles and Opinels. It seals the wood and after charring just use a paper towel or rag to remove the surface charring. Rub thoroughly to a semi-gloss. I've tried putting teak oil on afterwards, but it is so sealed it doesn't take up hardly any of the oil.
It's not hard to get the idea. Keep the flame moving and don't linger along the edges of the blade slot. The sharp corners will ignite, but quickly extinguish if it happens. You end up with nicely rounded edges once you rub it afterwards. Sounds crazy, but it works.
A variant of the charring technique would be to use a torch to flame in pine tar.
If I love knives, I am wholly committed to XC skiing and with old wooden XC skis, you need to prep the wooden bases with torched pine tar. SWIX, the XC wax maker, used to sell cans of pine tar just for this job.
You coat the wood with pine tar as best possible and then torch the pine tar till it bubbles, smokes and occasionally burns and as you do this, you use a rag or stiff brush to work the molten pine tar into the wood.
Done correctly the result isn't sticky, or at least not as sticky as you might imagine. More like a railroad tie. It does smell. Anyway, putting a top coat on it might help with the feel.
I've not done it but every time I see a charred Opinel, I think of it.
Pro tip: do this long out of nose shot from your wife or expect to be sleeping outside for the next week. Don't ask me how I know this and I honestly thought the windows on the house were closed.
Fair warning. I’ve never performed a successful blade removal, even after grinding the peens flat. Each time I’ve tried it (twice) it appeared that the peening process thickened the pivot pin enough inside of the collar to prevent the pin from moving even after the heads were removed. Others have reported success so perhaps I just suck at it.
If it were me, I would leave the blade in place for the clean up. But please keep us posted. Very interested in how it turns out now. Perhaps you’ll have better success than me (not hard)
You mean *180* grit, right? 80 grit is very coarse and will scratch the hell out of the wood. Those scratches will show up dark when you stain it. Even 180 grit is quite rough for a stained surface. Beech isn't very hard or dense wood, and I can't imagine it "rejecting" the stain with any normal sandpaper.My approach.
Remove lockring (or tape it to protect it).
Sand with 80 grit to remove stock finish. Stick with 80 grit to keep the tight beech grain as open as possible. Otherwise, the beech will reject the stain.
I am going to try that next time! What I plan for the one I am working on now is to coat it with olive oil and bake it in the oven at 375deg-400deg for a half hour. I've done that with the kitchen implements I've been carving, and it turns them dark brown, almost black (the hotter it is the darker; 350 will make nice rich brown, 325 red brown, etc). But to get a good baked on season coat it seems to require hotter temps. Even without the coating it creates a water-resistant surface that water beads off of, and even more so if you get a good external clear coat baked on. I am still developing it; sometimes it's too think and sticky, sometimes it all just soaks into the wood, which doesn't work as well. And I've never tried beech, so it may be an utter failure. But if it does work, it will be very interesting. I also ground the clip point off and turned it into a sort of drop-point, so I could carve the heel down more without exposing the tip.If you want a dark color, I have been using a propane torch to scorch/ char the wood. After removing any finish, of course.
I like the blade on the top one, looks like you just filed the tip down a bit?
