- Oct 20, 2008
So, I'm in the middle of grinding this here bowie. I get both sides roughed in to 60 grit. I start grinding the reverse side at A100, and I step back after a bit and compare to the first side.
The first side is roughed in more or less to my sharpie grind lines. The second side, after cleaning the flats a bit, has a stretched flat and longer transition than my original plan. No prob to adjust the grind back to plan, but I think it might be better... not sure.
It will be a hamon blade, with a bowie style guard, so consider that in your visualizations.
What do you guys think? Three shots of the obverse side, as planned, then three of the reverse side, in transition...
