Opinions in this type of finish? Taped off sand blasting
Was going for a different type of look and something new. Has anyone tried anything like this before and does it look sloppy? I polished the blade then taped it off and did a sort of camo type pattern then used a medium aluminum oxide sand in the sand blaster. Opinions?
I like it. Unique for sure. If it doesn't hold up finish wise then you can always blast the whole blade of remove the blasting finish.
Might rust at different rates du to different surface areas?
That's a good point that I didn't even think of. I wonder how it would look if I used some cold blueing on the sand blasted area? Or did the same technique with a ferric chloride dip.
