- Apr 15, 2002
The spyderco endura is everything you'll want in a knife. The FRN handle is light, and the metal clip, although it does come loose after a while, is still very secure. VG-10 is an excellent steel, with great edge retention, and high corrosion resistance. It is easily touched up when needed, and sharpens easily if it does in fact get too dull.
I carry a serrated one everyday, everywhere. I've used it aboard the lobster boat for about a month now, and have not wiped down the blade after use, and haven't seen any corrosion or even rust spots on the blade.
I got mine used, to fix up, and surprisingly all I needed to do was sharpen it, and tighten the clip, easily done with a dime or nickel.
Unless you pick up a defective model, you should have no problems with this knife for years to come.
My opinion would be to get the newer versions in either ats-55 or vg-10, FRN handled, and a serrated edge.
I myself am in the market for a plain edge, to try out at work. but I've always had an affinity for SE spyderco's.
Pete
Pete
