- Feb 25, 2007
I have a design for a machete/bolo knife floating around in my head. It is a fairly large blade of about 12" and I am going to use 5160 or 1095 for the steel.
My thought is to use 3/16" and go with a convex grind to a zero edge. My grinding skills are not up to the task of flat grinding such a wide blade yet. This blade will be a user not a show piece.
Here is my actual question. Can I get decent edge geometry for a hard use chopper without having to do a full flat grind on 3/16" stock? I picture a sabre like grind using slackbelt grinding until I get to the desired edge geometry. I understand that there will be a large portion of the blade that will remain untouched.
It is my thinking that many of the knives I see that are flatground .25" would have a similar edge and it would save me the frustration of trying to flatgrind 3" wide stock.
Please let me know your thoughts on the matter. Let me know if I am completely out of my mind for thinking this way. Thank you once again for all your collective knowledge and your willingness to share it.
Paul
Side not: 1095 or 5160 and what RC would you try to obtain?
Paul
