- Dec 6, 2004
remamber to save 500$ or so for start up tooling
I'd get the one with the square column.I am looking at a mill and may pull the trigger next month. Which of these two would work better for knife guards etc, but I also do bicycle frame miters, possible axles etc. Smaller pieces mostly, but a bit bigger than knife only.
http://www.busybeetools.com/products/MILLING-DRILLING-MACHINE-1.5HP-CX-SERIES.html
http://www.busybeetools.com/products/MILLING-MACHINE-WITH-DIGITAL-READOUT.html
If you guys are shopping for milling machines, but haven't had the chance to use one before, then I highly recommend 2 books before you go ahead and buy a milling machine:
1) Machine Shop Essentials
2) Machine Shop Trade Secrets
Knowing how to properly tram a mill, calculate feedrates, speeds, etc... are a huge advantage in getting good results with any mill. If you know this stuff right from the start I think it will help influence the buying process, and make getting started an easier experience.
As others may have said, make sure you budget between $500-$1000 for starter tooling. LittleMachineShop.com is a great resource for tooling for small milling machines and lathes.
So is the main difference between round column and square just the ease of set up?
I've been using a Sherline mill since 1998, cutting damascus, tool steel and titanium. The thing is tinny, but I've never had any problems. Never burnt up or broke any cutters. But found solid carbide is the way to go.It depends what you'll be machining, and where you're living.
I used a Sherline mini-mill for years (working just brass and nickel silver), but when I moved to stainless the little fella had to go. Broke and burned a lot of cutters and end mills. Now I use a full size Jet Bridgeport clone -figured out how to get the bastard to cut D2 almost like aluminum.
