Alan Davis Knives
Knife Maker
- Jun 28, 2010
Be sure to get bi metal blades. I use Lenox 10/14 & 14/18 vari - tooth.
Are there any HF stores around you. They can use the coupon code straight from your phone.
As for the bands I use the 18 tpi on wood also. But I only use it to cut out my knife. I like the fine tooth cut it gives. Easy to sand smooth.
As for the drill press I have a HF 8". It does the job but has had a good bit of chuck wobble since day one. Reworked every thing from the bearings to the chuck with no improvement. If I had it to do again I'd go a different way on the drill press.
Sent from my SM-G900V using Tapatalk
. I've also added some extra 18 tpi bands. Would you guys go with the multi purpose ones (for both wood and metal) or just the metal ones?
l]
