- May 10, 2007
It's probably because you aren't used to them. I open/ close amd re-clip my spyderco at work all the time with gloves on, never had a problem.
With gloves on I could do it no problem. I wouldn't be worried about cutting all of my fingers that I have to put in the way of the blade. While I CAN close it one handed it is NOT easy, and its also not easy to close it two handed. Its not that I'm not used to them. Ever since I closed my first lockback (probably when I was 10) I thought that it was a dangerous, awkward, and difficult way to close a knife. The biggest problem with it is that it takes a large amount of force to disengage the lock and then when the blade falls its difficult to control how much it rotates and is therefore likely to hit your fingers that you were required to put in the way.
I don't get why people whine so much about how hard it is to close lockbacks.![]()
I mean, while not as easy to use as, say the Axis lock, its just as easy to close as a liner lock.
http://www.youtube.com/watch?v=Av3HkTY7rLU
http://www.youtube.com/watch?v=LROTem-bYNU
I think that the axis lock is incredible and also fairly easy to use, but it also takes some getting used to, its not as intuitive as it looks IMO. I don't think its even close to as easy to close as a liner lock. I'm a righty and I figured out how to close my right handed liner lock left (one) handed fairly quickly and I doubt I could close a lockback left handed, in fact, I wouldn't try because of the danger of cutting myself. Its a poor design when compared to the axis lock and the liner lock. I'll have to watch the youtube videos when I get home, work blocks them
Axis lock pros:
very strong
fully ambidextrous one hand close
fairly easy to figure out
safe (closing)
cons:
liner/frame lock pros:
easy one hand close
fairly strong if made correctly
fairly safe (closing)
cons:
not fully abidextrous
not as easy to figure out
lockback pros:
fully ambidextrous
strong
lockback cons:
unsafe (closing)
hard to figure out
hard to close one handed or otherwise
my $.02
