Chuck Bybee said:
Now you changing the comparison to edge retention.
Edge Retention of 3V at charpy 85 = 6
Edge Retention of S7 at charpy 125 = 1
When comparing edge retention for 3V and S7 for the charpy values
you listed, 3V has 6 times or since you used percentages 600% more edge retention than S7.
Again, this depends on what the edge is going up against. The above may be true in a contest where you're cutting dirty rope or something, but it seems we all agree we wouldn't be using these steels for that application. (Well, actually, 3V not only has great impact toughness, but is also about as wear resistant as D2, so this steel really could be used for a wide range of applications. In fact, it aught to be about perfect for what most people do with bowie knives, though my own uses focus more on the shock/impact side of things.)
These steels are for big choppers that will take a lot of shock. If you're out clearing weeds in a junkyard, the S7 blade would likely have several hundred percent better "edge retention". As in, the 3V blade may be severely chipped, dented, or rolled from accidental contact with the junk, whereas the S7 blade just needs a good resharpening. (and just to put things into perspective, in that same application many lesser steels and stainless would be utterly destroyed) I have stated many times that I don't even care about wear resistance on my big blades.
I've gotten into very confusing discussions before, because everyone had a different idea of "edge retention". We all meant "the ability to retain an edge", but some of us were talking about wear resistance, while others were talking about impact resistance.
And this is where the origional poster needs to evaluate his own use. If you do a lot of slicing on soft materials, the knife may not be worth it to you. However,
I would just LOVE to have a big knife made of this steel, to try out. If you have ever actually broken knives during genuine hard use, this one will pay for itself many times over. (I didn't see the specs on the knife in question, but I'll give the benefit of the doubt to the maker that he knows what he's doing with this steel.)
TLM said:
...The standard test block is way larger than typical knife geometry. Toughness improves as size [of the stock] gets smaller. The phenomenon is also not continuous or linear with size and Charpy figures can be manipulated if the notch is not quite the standard or if the better option of fatigue notch is used. All in all I would not read all that much into the Charpy figures unless very specific test conditions are given and preferably the tests are done with a representative test piece size.
Though I understand what you're getting at, I hope that some of the newbies in question don't totally discount Charpy figures for this reason. Sure, the factory doesn't tell you how your knife will perform, but they're a good place to start when evaluating generalities of steel performance. For example, it would be completely illogical to look at the impact resistance figures for S5 and S30V, and then still choose S30V for a big chopping blade. (I suppose if you just wanted to nit-pick my post, you could say something about needing corrosion restistance, or whatever.) Just because they weren't testing a knife, doesn't make the tests worthless.
