I like the Trijicon Tripower Reflex sight for a long eye relief sighting system. The reason for choosing this sight for me was the inverted "V" or "chevron" aiming mark. It is the fastest acquisition of any sight I have used and gives a very accurate POA.
Here is a link to the sight picture :
http://www.trijicon.com/na_en/products/product2.php?id=TriPower&mid=TriPower
By sighting in the weapon so that the POA is right at the tip of the chevron, this gives the oppertunity to take deliberate precise aim if required and would be the equivalent of a 1 MOA shot. Which is excellent for refelex sights. Most dot systems have to be a balance of having a dot which is easy to pick up quickly ... but then avoid covering too much of the target for any precise use if wanting to engage at distance.
Dot systems that work fast cover off 2.5 MOA or more and the dot system only works by the POA being central to the dot. This is fine for "centre mass" shooting and ideal for burst fire but is not as precise as using the tip of the chevron for accuracy. Plus IMO the chevron actually directs your line of sight a lot easier to enable fast instinctive shooting.
This particular sight also has multiple illumination systems only requiring a battery for back up. As such it is very robust and reliable.
In comparison to scope optics I much prefer reflex sights for long eye relief shooting. The reason is that I do so much shooting with a scope that I am used to mounting the rifle looking for a normal 2 inch eye relief on a scope. Those which provide long eye relief I just find confusing/dangerous on a battle rifle. The Tripower sight which requires double eye operation is far better for me as they mount much further forward than a scope and my mind is not going to confuse the two.
These sights are not cheap but are a lot cheaper than a top end long eye relief scope. Compared to competing options such as an aim point they are always "on" and you don't have to flick a switch. Any switch system for sights intended for combat does'nt rate highly with me. It only needs to be "off" when you need it once ...
I have no problem engaging targets accurately at 300 metres and beyond with this system. Once you know the rifle and the load you are shooting the aim off technique works fine. Because you shoot with both eyes open the elevation hold over does not entirely obscure the target.
