- Aug 17, 2012
Hey guys...
I know it is probably a bit different for everyone, but I am trying to figure out what quantities of which grits I will find I am using in relation to each other?
I am planning on starting with 60 and 120 grit ceramics, and then using 320, 500 and 800 grit in AO's. Well I find I will be going through say only one 60 ceramic to every 2 or 3 320's (as an example)? I have been using a lot of 1084 and 1095 steels up until now and have been bevelling prior to heat treating (using a little 1x42 with a 1/2 hp motor), but I will be starting to experiment with more stainless varieties as well as grinding post heat treat.
I was thinking about order 10 each of the 60 and 120 ceramics and then 20 each of the 320 and higher. Is that realistic or well I be having to reorder more of a couple grits a lot sooner than the others?
I also want to try using scotchbright type belts for satin finishing. Should I only need a very fine with the grits ordered? How many uses can I expect before replacing?
Thoughts?
Thoughts?
