Orford / Krein / Dozier / AVigil / Carter /Humphrey / GL DREW
busterbones
Feedback: +223 / =0 / -0
Ben Orford Pixie $275 shipped
Blade 2.30"
Handle 4" Coffee bag burlap Neon green G10 liners and it has stainless steel loveless bolts and thong tube. It has a 2.5mm unpolished O1 blade that makes a great blade thickness for carving as it is not too thick, it has a razor sharp scandi grind and the narrow blade profile makes it perfect for spoon carving and other craftwork.
Krein TK1 d2 $325 shipped plus $10 if you want the tek-lok
lightly carried has some tarnishing on the tip can easily be polished off.
Stiff Horn Sneak $150 shipped new!
AEB-L 3.25" blade, OAL 7.25" hollow ground, Rockwell 62c with liquid nitrogen cryogenic treatment.
Hollow ground on a 10" wheel.Finished to a 400 grit then given a non reflective glass bead blasted finish.
The scales are coarse texture black G10 mounted with 6-32 bolts into custom made brass threaded rod.
Knife weighs in at 3.7oz
Dozier $235 shipped
KM-5 Bodyguard
Overall Length: 7 5/8"
Blade Length: 3 1/2" at 60-61 Rc.
Lon Humphrey rustic bravo $215 shipped
Carter Muteki Series Pipsqueak
STEEL: White Steel laminated with Stainless Steel
FINISH: Forge Finish, unpolished $250
with joufuu sheath and a black index sheath.
Northwoods canoe
Mammoth Ivory D2 steel
$250 shipped
GL DREW whittling set
$125 shipped
