OT:Who's got a Swiss K-31?
I used to frequent surplus houses, in the old days when I got my 98 Mauser carbine in 8mm. The Swiss straight pull carbines used to have safety issues with the bolt.
Have these been corrected in the models that are for sale now?
I liked the security of the old Mauser action, but it was a long throw and slow. I regret selling it.
I think the only safety issue there is having a trigger that light on a military weapon. ;) The thing's even got a decocker, kind of.
In all seriousness, plenty of modern military weapons have safety issues of some sort. The US rifles (from the Garand on up) can slamfire among other things. It's highly unusual, even if you're dropping the bolt on an already-chambered cartridge, but it happens often enough to be mentioned in the tech manuals and some reloading guides. ("Don't use soft primers!")
I haven't had the Mauser itch for years...ever since my M48 went kB! I don't think it was the rifle's fault but my brain associates the two now.
What exactly were these issues? You've got me worried now.
Yvsa said:
I just wonder if ammo can be had for the Rolling Block 12.7 X 44? Hell that would be a .500 caliber wouldn't it!!!!???? :eek:
I also wonder how it would compare to the old Sharps Rolling Block.
It is basically an equivalent round to the .50-70 Govt, and uses the same dies and bullets...brass can be formed from .348Win cases cut off just at the shoulder, or bought from Buffalo Arms at a $1 a pop...there is no need for crimping and very little need for sizing in a singleshot...oh, and dies are about $70....the BP guns that Ken sells are priced $50 less than the smokeless 8x58R Danish Krag I got...it SHOULD be converted from the original rimfire to centerfire, but that should be nailed down when the order is placed, along with bore condition, no scope mount holes, sound wood with no cracks, etc....FYI, even a shiny bore in guns this old can be expected to have pitting in grooves, and should shoot fine...if you buy the lower grade of guns ($200 in BP/$250 in smokeless), you get no guarantee except that you get an excellent action, with no representation as to sights being there, chunks of wood missing, sewerpipe bore, etc even covered, and I get the impression from him that if the gun has obvious problems externally, he just throws it on a pile with no further examination than a functioning action....also, the smokeless gun I received looked far better than that BP version in this post, and more like http://www.gunboards.com/forums/uploaded/befus/200563172417_rolling blocks 001.jpg....and as far as comparison to the Sharps falling block, there were about 30,000 Sharps made back then, and about 900,000 rolling blocks made by Remington alone, much less the guns made under license in Sweden, Denmark, Spain, etc etc etc...it was THE most successful singleshot military weapon of all time and was produced from 1867 well into 1917 and the modern era....
Edited in PS....sorry about the thread hijack, Stevo...
never heard of bolt issues with the k31.
Only bolt issue I can think of would be if you fired GP11 or other modern ammo in a 1889 rifle or sporter built from such a rifle. The 1889 was only designed for 30-30 or 30-40 krag type pressure levels.
If someone rebarreled an 1889 to .308 or loaded GP11 in one, that is not the guns fault.
If you have a gun with a mismatched bolt, you should have the headspace checked, although I have yet to hear of even any problems then. Still should check it though.
Only other thing is that during WWII they experiemnted with some alloys in the reciever. You should be able to track down the serial range at the swissrifles.com site. Still never heard of any major issues on that score either.
Nomanmade object is perfect, but the swiss tend to be mighty careful with their firearms!
Yvsa, as much as I like Sharps rifles, the Rolling block is simpler, probably a good bit stronger, and easier to operate from the prone position. For those prices, I am guessing the action alone would be worth it.
Must resist, just got news that a $250 copay is coming for colostomy stuff for Tim...
Tom
The Mauser 98 had an extra safety lug. As I recall, the Swiss straight pull didn't have the sorts of lugs that you see on a Mauser. There were some reports of the bolts blowing straight back - like the slide on a Beretta 92.
I heard of these many years ago, but don't know if there have been any others.
They could have been from a series of guns from one arsenal, or from guns that weren't stored properly...don't know.
Satori said:
After having spent some years shooting Mosin-Nagants, the cocking ring on the K-31 is a joy to use.
Hey Satori,
Oh great vid guru how about a short vid of the fireball from the end of a Mosin M38 or 44? :thumbup:
I am unaware of any issues with the K-31, or even the older (weaker) ones when used with the appropriate ammo. The GP 11 ammo is loaded to lower pressures than say .308 ~ more akin to the 6.5x55 Swede. The lack of the third lug is theoretically a weaker design, but remember that the 96 Swedish Mausers don't have them either, nor does our current M-16 or a plethora of other modern autoloaders. My guess is that the failures in the past were with older models (rear locking non K-31) that were converted to high pressure .308. Contrary to what was stated, the bolt head of the K-31 has large dual opposed lugs just like a standard bolt action does. It does not, however, have controlled round feeding like the Mauser with its large hooked extractor.
2 cents from me, mr. no sense ;)
As far as bolt failures are concerned, I recall Hatcher doing a bit of "research" along these lines. (His research typically ended in something blowing up but it makes for fascinating reading.)
Here's my point of view as an armorer:
Most firearms, today and yesterday, are massively overbuilt. There's a tremendous safety margin engineered into them from the beginning. If you doublecharge a rifle cartridge you'll usually blow the sucker up but there's only so much that you can realistically engineer around. I've seen some firearms (usually pistols) that will tolerate a double charge...not a good idea, but that's how overbuilt they are.
I've seen a few guns go boom - my M48, my room mate's FAL, an M16, and an M14. It's worth noting that in none of these cases was the shooter seriously injured. I picked up a powder tattoo on my forehead from my little accident. The room mate caught a few bits of brass in the face. The M16 shooter wound up with a gas cut and some aluminum cuts, the M14 gunner was fine. In all cases the shooters were wearing safety glasses. In all cases, I believe that some eye damage would've resulted without it. (My own safety glasses looked as if they'd been sandblasted and had to be thrown away afterwards.)
None of the weapons were fit for firing afterwards, of course. The FAL survived and the M48 probably will after some extensive reworking. The M14 and M16 were goners.
The Mauser's safety lug gets undue attention. There are some other bolt guns that deleted it simply because (as was mentioned) it's really not necessary; if you have enough bolt thrust to break the two primary lugs, that third lug ain't gonna do much. The root of the bolt handle itself probably provides more support. The normal mode of failure (as I understand it) is that the lug taking the lion's share of the thrust shears and the bolt cocks to the side, essentially jamming itself in place.
Take a look at the locking lugs of modern military firearms...and even some not-so-modern firearms. Forget the M16 (which has a bunch of little locking lugs) and look at the much-touted M14/M1 Garand. There are only two lugs, they're not too large, and they lock into the receiver instead of the barrel. From a firearms designer's standpoint this is a bad thing for a variety of reasons that are beyond the scope of this post, but it works and works well. The much-praised H&K roller locking system uses considerably less surface area for locking but not too many folks complain about that. (If you get the chance, look at it sometime. It's scary.) A design that seems like a bad idea on paper is not always bad in reality, and vice versa.
The Beretta slide comparison is a bad one. This is truly a case where a couple of failures, a long time ago, created a true mythology. There's a lot to this story: Beretta said that the ammunition was overpowered (true), and the government said that the steel was substandard. (Also true.) The ammunition was downloaded a bit, the steel was upgraded, the design was modified and there hasn't been a problem ever since. (Not that problem, anyway. There are others.) I haven't heard of a slide seperation since I've been on active duty. (1996.) On second thought, it may be a good comparison...a couple of hiccups early in the weapon's lifetime and the reputation is earned.
No safety lug? Not a big deal to me. The M14 doesn't have one. The AK-47 doesn't have one. The M2 doesn't have one. The M242 doesn't have one. (What a set of locking lugs that thing has, though...) In short, were it necessary, people would still be making them. The militaries of the world realize that it only takes a couple of failures to cause a lack of faith in the weapon system and they take great pains to avoid this.
My guess is that there were a few failures - probably from improperly loaded ammunition - and it started from there.
HD - good idea for a vid. No promises, but if the opportunity presents itself, I'll generate a few fireballs for the record.
Have I mentioned it lately? YOU ROCK! :thumbup:
