Glue it, screw it, pin it, use corby bolts, or rivets. I prefer using screws, button heads and counter boring the boles just enough so the head is just below the surface of the handle. With screws the scales can be removed and changed or the tang and underside of the scales can be cleaned if needed. Some folks like the look of an epoxied handle, I guess it gives it a more snug finished look but if you sand your blades and scales flat, you don't need epoxy to fill any gaps.
Micarta, G10 , tell me how to put it on
