- Oct 3, 1998
I don't know whether this should count as a "first review" for contest purposes, since I got the knife wholesale.
Here's the link to a high-resolution scan of the Impulse and also the Magna:
www.chaicutlery.com/outdooredge/oe-impulseandmagnascan.jpg
And the clip sides, closed:
www.chaicutlery.com/outdooredge/oe-imulseandmagna-closed.jpg
It's a factory rendition of a high-end custom knife, done with a working class price target - $55 msrp.
I like the feel of the handle, with that round swelling next to the clip. That seems to help give the clip a little more purchase, by pushing cloth up against it sideways. The clip, being recessed, is more comfortable in the hand than most.
I haven't tested edge holding. I've only had it a few hours, and I'd like to keep it "virgin" for the customer. The factory edge passes the arm hair test.
The lockup passed "spinal tap" test for me. The one I'm looking at right now locks up on the near side of the tang. I think the other one was in the middle somewhere. The one I'm looking at now has a tiny bit of sideways blade play, which should be correctable by a quarter turn or so of the pivot screw, as suggested in the instructions.
I'm a fan of firm ball bearing detents in a liner lock. I like a good speed bump there. I got two Impulses. One of them has what I call a good detent, in that it takes a hard shake to "flick" the blade. The other one has a detent that I can feel, but only a slight shake flicks the blade. Ball bearing detents are tricky.
The clip is a deep pocket design, and the top of the clip is diagonal instead of horizontal. It must want to ride in the right front pocket, where it matches the angle of the pocket. In that position, you can grab the blade by the cut-outs and open the blade in the pocket, so that it's fully open when you pull it up from the clipped position. This feature may be useful in some specialized situations. I'd like it better in the one with the good ball bearing detent.
I haven't tried David Rock's idea of blowing bubbles with the holes in the blade.
All for now . . .
[edited to correct image reference]
- JKM
www.chaicutlery.com
AKTI Member # SA00001
[This message has been edited by James Mattis (edited 29 August 1999).]
All for now . . .
- JKM
www.chaicutlery.com
