- Apr 1, 2009
I would not expect much (if any) reduction in element life using inert gas. The Oxide layer, once established, should not decompose at normal use temperatures and it will see Oxygen every time the oven is opened anyway.
Using cheap N2, it should not be a problem running a higher flowrate. With a timer and a solenoid valve, it should be relatively easy to bypass the needle valve and give a short blast of shielding gas at high flow immediately after the door is closed. That should be pretty easy to set up, given that you built the oven and know how it is wired.
I seem to recall your oven being fairly large: roughly 6" x 6" x 27"? That's "about" 1/2 cu ft, so at 6 CFM, you'd expect to halve the O2 content of the oven atmosphere about 12 times an hour or once every 5 minutes.
Immediately after closing the oven, you'd have 21% O2, after 5 minutes; 10.5% O2, 10 minutes; 5.5% O2, 15 minutes; 2.75% O2, 20 minutes 1.3% O2 and so on.
If you put in a 5 minute purge timer that gives about 25 CFM (the upper range limit on my welding Argon flowmeter), you'd halve the O2 every 72 seconds or so and you'd be down to about 1.2% O2 when the timer timed out.
