- Feb 28, 2011
H&K 14715, Cold Steel Ultimate Hunter or Manix 2 XL would all fit the bill.
I'd say hands down the ZT MUDD 0500. The problem with working in dirt is that debris will cause lock problems in almost any lock - sliding type (liner, frame, compression), back lock (backlock, Tri-Ad) or compressive (Axis, ball bearing). Plus it's a real pain to clean out a knife lock, and even worse if it's something you'll end up doing every day. The 0500 is specifically designed for uses such as yours.
If you can't find a 0500, at least shy away from Axis/bearing locks and ball bearing pivots as I found these to be the biggest headache when it came to debris in the knife.
