- Nov 19, 2008
Replacing the stop pin on a folder can present another issue though. Many (not all but many) folders use the same stop pin in which the blade rests in the open and closed position. If you increase the diameter of the stop pin he blade will no longer rest at the same point when closed. In some cases the detent wont line up with the hole in the blade.
Not with the small difference in diameter needed for the lockup to change. I have done this multiple times and its neither of those problems have ever been an issue. Heck wrap a layer of electrical tape around a stop pin right now and try it. You'll see that lockup changes significantly but the detent will still be fine and no way the tip is standing proud. If it did you could just sand down the kick with a sharpening stone though. The detent is a non issue because the pressed bearings in the lockbars are undersized for the holes in the tangs in the majority of knives. Go try it.
