I've had one large, long ( 1.5" wide, 3/16" thick, 9" long blade) bowie-type O1 blade that I ground from barstock (no forging on my part) that exhibited some minor warping along the tip during HT. It was quite thin at the tip - nearly-full distal taper, full-flat grind, "swedge" in the neighborhood of 40 degrees, maybe less. As you can imagine, that sort of design involves a lot of very aggressive stock-removal.
My HT guy had to bring it back up to tempering temp a third time, to straighten the tip. He told me, "That just happens sometimes. You stock-removal guys can obviously only grind one side at a time, and that puts uneven stresses on the steel." (I'll presume that my hammering brethren can only pound on one side at at a time) His explanation was that the extra tempering step helped remove any residual stress, and he was confident that the blade was good-to-go. This is a guy with 25 years' experience, who has HT'ed more blades than most of us will ever see.
I still have that blade. While I trust my HT guy very much, I'm still leery of it.
Again, this is an extreme example,,, and I may be just over-cautious. But it seems to me that more awareness of heat during forging/grinding, and an extra step of normalizing before HT couldn't hurt.
