Hello all. I use a 204 sharpmaker to sharpen my knives,there is a bit of a learning curve in getting to learn how to use it but once you do get the hang of it you can really up the perfomance of blades. I sharpen mainly at 40 degrees 20 each side, & will start on 30 degrees 15 each side soon on a couple of higher end steels to see how much sharper they will get. My question is , once I have the knife shaving sharp on the fine rods at 40 or 30 degrees what happens if I keep going. Will I thin the blade out too much, roll the edge or will it crumble under the force of a cut. Or will it continue to get sharper & not turn into dust because the sharpening angle is either 40 or 30degrees. Im still a newb so any info would be great.
bas.
bas.
