- Mar 1, 2010
It is for looks: blade will break first!
Proof of that?
I am not really ready to break a knife to prove the point. But I have not heard about broken pivots in any destruction tests that I have read about or seen: it was always the blade or the lock. Have you heard about pivot failing first? I am not challenging, just curious.Proof of that?
Like Poez, I have no proof but the anecdotal reports here on BF about broken folders always seem to be blades and locks, with a rare stop pin incident or two. I have never read about a folder that failed at the pivot. Maybe someone who reads this thread can report an instance of this happening.
Cheap swuss army copies fail at the pivot, the design is basically a bunch of brass pins pressed into holes. In the day, the bone and brass old school stuff could eventually fail, but the user would likely break the tip off first. Hence "the blade will break before the pivot."
Looking back on knives used since the '50s, it's more than a "IMO" or anecdotal view.
The reason is that very few pocket knives use differential heat treating to make the edge hard but leave the blade back softer. Most are heat treated whole in the ovens by the thousands, and if there is lock back, it gets thrown in, too. Many companies didn't temper them spring soft, one reason issue military knives like the Camillus would break back springs. Very common to find them in gun show cases like that, the springs were tempered too hard.
Huge pivots are basically tactical decoration - normal ones put up with everyday abuse for years, making them 400% bigger is really just for looks. When the "beat me and make me bleed" uber folders started coming out twenty years ago, the makers chose massive pivots to make their knives look the part. When spine whacking started soon after, the majority of results were failed locks for either type - not pivots.
Those of us using them since before the invention of the internet or youtube learned it without needing somebody's unscientific video of how cool they are.![]()
I don't see fat pivots affecting friction very much either way. A folding knife is only as strong as its weakest component, and that weak link is almost never the pivot. I also see very little downside to a larger pivot, within reason. Make it too huge and other parts will have to get bigger just to accommodate the pivot.
