The mechanical keyboards provide greater comfort when it comes to writing because the type of touch the fingers are more rested, in addition to the comfort they offer in the pulse, all without mentioning the wonderful sound so characteristic and make them favorites of the typists. How do you get all this? It is very simple, in the non-mechanical keyboards have a membrane for all the keys while in mechanical keyboard CK88 find an individual pulsation mechanism for each key.
The Motospeed CK88 mechanical keyboard has a comfortable design designed to withstand long days of work or play, is something that Motospeed has in mind in each of its keyboards, having a foothold and its ergonomic design makes it reduce the feeling of tiredness in the fingers and wrists. But, undoubtedly, something that has separate mention is the lighting of this keyboard based on RGB LEDs that you can customize with the different lighting modes and that will make you gawk while watching, and do not worry, its intensity is also adjustable so as not to dazzle at night.
The Motospeed CK88 has a switch, which is what we call that mechanism, blue, this means that it is a medium touch, it does not lead to being as hard as a black one nor as soft as a red one since the pulsation is activated right midway. It is a good type of switch for both games and for writing, because by the type of pulsation it is very difficult to push a key by mistake, something great for games in which precision is needed above all. As soon as you try the Motospeed CK88 RGB mechanical keyboard you will fall in love with it as we have.
Product Features:
● 16.8 Million RGB Color Backlight
You can set different color modes just according your favor. With RGB LED lights built under the keys, you can make your keyboard unique from others.
● Full Mechanical Blue Switches
With 50 million times long press life, 60 gram trigger pressure and 2.5mm trigger range, the full mechanical blue switch is the best choice for the players.
● Comfortable Arm Support Board
Designed to relax and rest your arms, the arm support board comes with the keyboard. Your arms will no more feel tired after long time typing or gaming.
● All Key Strikes Without Collision
Even at a minimum chance, you can press all the keys at one time and there will be no collision for typing. Easy typing and input, no more worry for the key collisions.
● Dual USB Port
Adapting premium material, the cable is durable to different temperature. The dual USB port can provide enough current to the keyboard for both typing and lighting.
● Full Programmable Keys
Any key on the keyboard can be programmed to certain functions and colors. With the professional software, you can choose the best settings according to your need.
CK88 will satisfy you while gaming, the comfortable touch make it the perfect choice for gaming lovers. Made of high quality material, it can provide long service time for you. You can go to GearVita to obtain this wonderful mechanical keyboard: https://gearvita.com/motospeed-ck88-mechanical-keyboard.html
Related products:
https://gearvita.com/motospeed-ck10...-rgb-switch-real-blue-with-led-backlight.html
https://gearvita.com/motospeed-k83-keyboard-keypad.html
Product Features:
● Dual USB Port
Related products:
