Here is what I use - the total set up is far less than a pair of socks from Kifaru
Seriously the following set up is very affordable and functional... I just got back from 10 days of traditional muzzleloader elk/deer/bear/mtn lion hunting giving this tent and stove system a workout. The weather was beautiful (which means it stunk for hunting). Clear cold nights down below freezing at 3000' elevation. With my stove I averaged 68 degrees regularly while it was freezing or below after the sun went down.
I literally slept on top of my cot every night because my shelter system was Costa Rica comfy. I have a custom made 10'x10' tent that takes one man 15 minutes to set up or tear down. It is water proof, snow proof and good in 50 MPH winds. It is built with multiple redundancy -two loops on each corner in the event a stake doesn't hold or it tears (highly unlikely)...two ways to suspend the roof - traditional which I preferred or you can suspend it with a rope an have no center pole.
Having a wood stove is nice! The tent is now in it's fifth generation and is made from the finest and most expensive rot proof, water proof marine canvas. The designer only uses #10 YKK zippers. This tent design has been used successfully in some rugged situations and comes through with a smile. The roof is 40-45 degrees which is ideal for snow and rain. If you want one let me know and I'll turn you to the designer who designs gear for some really high-speed low drag types.
Finally on the second to the the last day we got rain - hard rain of Biblical proportions...nary a drop inside. Just built a fire inside to take the chill off...crank up the heat - open the window and door to draw the condensation out for 12 minutes then close it up for a warm and dry evening reading of Jedediah Smith and his wanderings here in Orygun.
I burned Cedar - left of stove (for starter and when I wanted to cook with my Griswold and Wagner Cast Iron)
and Madron wood - right of stove (one of my favorite hard woods only seconded by hickory which we don't have here in the Pac North Wet!)
I chose to go with the traditional "elk hunting - lodge" look with some poles I harvested the same day I set up camp. I could have used the supplied "galvanized" poles but am reserving them for an emergency situation. Also you can fully suspend this tent without ANY poles if you choose too.
Everything in this tent has redundancy...as you can see dual peg loops "just in case"
Everything in this tent has redundancy...dual roof suspension system - loop for horizontal pole or use rope over a limb"
More redundancy - Roof cap has one layer of thick PVC sandwiched between two layers of canvas.
Weather was too nice...elk and deer are on vacation! At 3600' elevation
