- Dec 22, 2006
Here's a little flashlight that is about as minimal as you can get.
Made by an outfit in Oregon and comes in a bunch of colors, infrared, basic, deluxe, etc. See http://9voltlight.com/home
I'm a cheapskate so I bought the basic model with the little Cordura belt case. It works great and makes an excellent tent light. The lamp base glows in the dark, making it easier to find at 3 AM. They claim 60+ hour life with a lithium 9v battery and over 30 hours with a quality alkaline. The light pattern is very usable. The manufacturer does not publish a lumen rating, but I found it more than bright enough for reading and camp tasks.
Two things I like-- it is easy to change the battery by feel in pitch darkness and it weighs just 1.5 ounces with the battery.
I don't know how it would perform when wet and I'm not going to dunk mine to find out. I'm sure it isn't waterproof. The switch design is open to water and the circuit board shows no sign of sealing.
The manufacturer covers this in their FAQ: "What if my Pak-Lite gets wet?
In some cases, the Pak-Lite's LEDs will glow dimly in the off position for a few hours. This does not indicate a malfunction with your Pak-Lite, nor does it drain your Battery significantly. However, you can unsnap it from the Battery and let it air dry, or use a hair dryer to remove the moisture quicker."
Sounds like it would survive a dunking. My guess is salt water would kill it.
Other than that it makes a very compact and inexpensive flashlight. It should make an excellent glove box flashlight too.
