I made a knife handle from paper micarta yesterday, first time working with this material. It is the cross cut mocha paper micarta from Pop's. The picture does not quite do it justice, it has a lot more depth than I was able to capture with my phone's camera.
I swear this stuff burns before you even turn on the grinder! I had no luck with a pretty new 36 grit ceramic, it would clog and then burn the handle very quickly. I ended up using aluminum oxide J-flex belts up to 240 and that worked well enough. I frequently cleaned the belts with an eraser and compressed air. Since I did not have anything higher grit in J-flex AO, I went to Trizact belts and immediately got a burn mark. Maybe I ran it too fast or with too much pressure? I went back to the AO belts to get the burn mark out and then sopping wet cork followed by a super fine Scotchbrite belt. I like the finish, but I am wondering if there is a better way. I have three more blades ready for handles that I want to use this material on, so I am wondering what y'all recommend for heavy material removal and for finishing paper micarta. Do you put a finish like wax or oil on it or not?
Also, does anybody know if micarta has a tendency to shrink and expand like wood, or is it pretty stable? I am contemplating a handle with dowel construction using a metal spacer, maybe copper.
