Well I have been carrying mine since Thursday last week, and so far I'm calling it GTG. Previously I was carrying a Tenacious and then went to a Bugout since at the time, Spyderco didn't really have a smaller LW knife with the usability I wanted, liner or compression lock, and a factory deep carry clip. I did not want a lockback, or the native LW would have been a top pick.
So when the Para LW came along, I was rather excited since I much prefer Spyders over Benchmade. While the Axis lock is a nice and smooth, it also relies on the omega springs and I have seen to many of them break to have 100% confidence in the system. I have always preferred the liner lock style locking systems.
Now back to the Para 3 LW. No it isn't as light as the Bugout, so just over 2 OZ isn't noticeable to me, even in gym shorts. It accomplishes what the bugout does as far as weight. The thicker blade stock of the Para I prefer over the bugout as well, which attributes to some of the added weight. Again I'll trade a thicker blade for a little added weight. While I don't pry on things with my knife the added blade material is a comfort.
I don't find the Para 3 LW to be blade heavy at all. The balance point seems to be right at the blade stop pin. FWIW it is in the same spot on my bugout.
I do like Benchmades Combo edges far more than Spydercos, and I typically prefer a combo edge. Being an LE, there are a few times when serrations accomplish the task slightly easier than the sharpest plain edge. Sypderco usually has almost half their edge serrated on their combos. This can detract from the every day usage of the plain edge. Benchmade usually does a 1/4 serration, so when you need it they are there, and when you don't they aren't in the way. It's more of a personal preference, and a plain edge works just about as well for my intended tasks.
The scales on the Para 3 do feel cheap when compared to G-10, but no worse than the BO's scales. Spydercos bi directional texturing is far better than the Bugout. The Para scales are sharp on the inside, but so were my bugouts. I disassembled the knife, hit the inside edges with 600 grit and in 15 minutes all was well in the world again.
Ergos go to the Para3 at least for me. The Para3 just fits my hand better, and feels more like it was made for me. The bugout while nice, seems very generic, like it was made to fit everybody just ok. When I put it to some cutting task like boxes, I really had to pay attention to keep it oriented correctly when really bearing on it. This isn't the case with the Para, it stays locked in even when I bear down on it. The para 3 erogs for my hand are better then the Tenacious.
Both knifes have a solid lockup, are easy to open one handed or flip with the thumb. The spyderco hole is far easier than the thumb stud for me anyway. I typically opened it holding the axis lock back. With the Para I can hold the compression lock and flick it open, spyder flick it, thumb flick it or drop open it. All options work well with the spyderco.
My Para 3 came out of the box with a very close blade center, and blade tension was perfect. Opening and closing was perfect with no blade play. I have no complaints about the lack of dual bushings, as long as the knife stays as smooth as it is now after years of use.
I am by far no anywhere close to a blade steel snob, nor do I know a whole ton about them. As long as a blade can hold and edge well, cut clean, and take and edge without having to pull out a grinder, it's good with me. The one thing I did find about the S30V on my bugout, if I ran it against a staple or some other metal object while cutting, it would catch a small chip. I haven't run the CTSBD1N against anything like as of yet, so I can't tell how it will do. It will however cut up boxes with ease, and go through a few zip ties, and it is still as sharp, hair shaving sharp as it was when I got it. You do have to remember I ran a Tenacious for a long time, and the only complaint I had with it was it wouldn't hold a blade well. I swear with little to no use, it would loose it's edge quick.
If someone goes out looking for a 3 inch lightweight deep carry knife, the bugout and Para 3 are going to be top picks. For me since I prefer Spyderco, the Para3 LW is a no brainer for me. The same can be said for the Benchmade fans. The Bugout still has a slightly smaller footprint when carried, but the Para3 being slightly larger, also attributes, to better ergos for actually cutting things IMO.
For you Para3 G10 guys, don't expect it to be at the same level, cause it isn't. If you realize what the Para3 LW was designed and built for, then pick one up and enjoy the crap out of it. I am very happy with mine, and look forward to some other options with them as well as the Sage 5 LW coming out.
For 90 some odd bucks for a solid Spyderco knife you almost can't go wrong.
TXPO
