- Aug 27, 2004
I have been buying and selling a lot here lately in the way of knives. In my buying I have specifically been looking for a knife that will meet all my needs. I won't get into all of that here. I will say I thought I had found the holy grail of knives in the Manix but it proved too large really to be effective for me in more delicate tasks like whittling and carving which any knife I carry must do and do well. While it was possible to do some real heavy chores with the Manix the real delicate stuff was just a bit awkward with it. I did love that knife though but sold it nonetheless.
I found a great one in the Para-Military. I must say it is quite nice. In a way I categorize the Para-Mil as a "Mini-Manix" because of a few changes in the handle grip and lock but basically the same style of blade in a slightly smaller size. I have been using it now for a few days and feel some things are worth being mentioned.
I love the blade shape. The size of the Para-Military is also great. It fits my hand so well I could not have made it myself any better. The lock took some getting used to but now I can open and close it with one hand as easy as any liner lock or lock back I have. Out of the box sharpness was great as usual for Spyderco. No grittyness in the opening. It was smooth as silk from the first time I opened it up. It has just enough texture on the G10 handle scales to make it very comfortable and tacky and yet still slide into the pocket easy.
One thing about Spyderco they have the edge geometry down pat. The knives from this company just cut real well. This knife cuts and slices like a thinner knife. I know, as I've been doing quite a few tests of my own with it and I am very impressed with it's performance.
I won't get into details of the blade thickness or other things that have already been covered in other threads. That would be redundant. I will cover what I have seen and feel needs improved upon. Some of that can be seen here in a thread I started on one of the Spyderco forums http://www.bladeforums.com/forums/showthread.php?t=344251
As you can see from the link to that thread the first thing I did was modify the pocket clip on the PM. The original tip down clip bit into my hand some when using it for certain chores, but that was not the only reason for my change. I simply like tip up carry mode better for a number of reasons. Number one being that I can reach deep into my pocket to get keys or something else without scratching myself on the blade spine or the finger grooves. The Para-Mil has grooves on the top of the blade for the thumb. These can hurt you when you rub them accidentally with your hand while reaching into the pocket. That pointed end on the back of the tang of the blade that hits the blade stop when you open the blade is also quite prone to 'get ya' when in the tip down carry mode. Lets not forget the fact that the knife comes out of the pocket just the way you want to hold it when the clip is in tip up carry. This is the only thing I have found that could be improved upon with this particular knife. I understand Sal Glesser is considering making it adaptable to all modes of clip carry positions on future models.
The Para-Military works well. It works so well that I'm really excited about this knife. It does the chores of a smaller more delicate knife as well as some upwardly heavy chores just short of what the Manix could do. It will slice carrots and apples as well as dice and perform other food prep chores well.
I actually believe the lock on this PM would give the Manix a run for its money as far as strength goes.
In a survival situation it would be quite easy to make your own utensils or some kind of primitive shelter with this knife in the right hands. Kindling is not a problem to make either as I did that just to see how much I could make in 10 minutes time. It handles this responsibility well in my opinion. No problem starting the grill or the home fire place last evening using nothing but the Para-Mil to make the kindling. (got down to 29 degrees last evening here so it was perfect timing)
As for edge holding. I will say this. S30V is very impressive. It has not needed touched up yet in any way shape or form after doing the above listed tasks. I have a floor full of shavings because of this knife from all sorts of both hard and soft woods. It is up there with D2 in edge holding. At this point I could not pick one steel over the other. But S30V certainly holds it's own with D2 for edge keeping based on what I've seen. The PM blade won't shave hairs anymore but it does still cut well and in a real tough situation it is still very useable as is. Here soon I'll find out how hard it is to bring it back to that biting sharpness it had out of the box.
My opinion of this knife is that it is one of the best offerings from Spyderco right now. I have bought 15 various Spyderco knives in the last 45 days, both new and used. Of all of them I am most impressed with the Para-Military for my own uses.
If you are looking for a worker look no further. If you want pocket jewelry this may not be your cup of tea. This is working class all the way and work it does. Very impressive design Sal.
From my observations there are only two things that could be better with this knife.
1: fix the clip issue and it is a perfect package as is for any right hander in this owners opinion.
2: Mirror image the whole knife so the lock is on the opposite side and make some in limited numbers at least for the south paws out there and you'll then have all the bases covered.
This knife is too nice to not let the leftys in the world experience it too. Because of the way the lock is situated I don't think any lefty is going to be too interested in this one as is.
Here are some things I've done so far with my Para-Military to test its ability to do more delicate tasks. Just a pic of some primitive utensils I made pretending to need them in a situation where none was available. I actually ate with these last night. Took about 20 minutes to make each of these using nothing but the Para-Mil and a small piece of sand paper afterwards. Granted the sand paper would not be an option in a real situation of survival but I did it anyway. The Cone head was to entertain my nephew long enough to continue on to more serious tasks. But anyway the point is the knife works.
