- Feb 1, 2010
Up for sale are three variations of my Twister models. Normally I grind these from 1/8 inch thick 1095 steel but got a heavier 3/16" thick stock by mistake in my last order. If you've followed my work you'll notice the flats on these blades appear different than usual. This is because the 1/8" material has a thick hard mill scale which I leave on the flats and bake oil into giving a good durable protective coating plus it provides a nice contrast with the grinds. The 3/16" thick steel does not have the
thick mill scale, even though it is hot rolled, and is not suited for a protective coating so it is ground off to give the blade an all steel classic look you see the photos.
I'm only charging $5 more for the heavier blades to make up for material even though there is more grinding and processing time.
SPECS:
Model: Twister Tanto
3/16 inches thick 1095 carbon steel differentially heat treated with and edge about 60 Rc.
Blade: 4.8 inches long from the tip to paracord wrap
Overall Length: 9.25 inches long
Handle: Coyote brown paracord tightly wrapped on the knifes full tang. The tang is sealed under the wrap to prevent rust.
Makers mark on spine.
Sheath: Coyote brown kydex drill to accept a Tek Lok large.
SOLD Price: $55 plus $7 shipping anywhere in US.
I prefer paypal (my account is kelley_ward@keysight.com Note: there are 2 "e" in kelley) but accept other forms of payment.
Model: Twister Spear Point
Blade: 4.6 inches long from the tip to paracord wrap
Overall Length: 9.1 inches long
Model: Twister Clip Point
Overall Length: 9.5 inches long
SPECS:
