Paragon 2400 deg Elements
GerryRandall
Does anyone who has a Paragon 14 KM series oven with the 2400 deg. elements have problems at holding temps?
I can get mine to hold at 1930 deg. within 1 deg., but anything less it just will not hold within several (8-15 +/-) degs.
Just need ammo with Paragon.
Thanks for any info.
Gerry Randall
Gerry Randall
I have the km24 and it seems to hold around +- 4 to 6 deg.. I figuered this may just be the norm. I wish it was just 1 deg.
Guys
First let me say I don't own nor have I used a Paragon. However, most controllers have an adjustable hysteresis ( how many degrees swing between when the controller turns off and when it turns on again) i.e. if you have the set point set at 1650°F and the hysteresis is set at 5° the controller won't turn on the heating elements until the temperature drops back down to 1645°. You can also throw in a chunk of 1/2" plate to act as thermal mass. The over won't heat up as fast, but temperatures usually drift slower the more thermal mass you have.
Jim Arbuckle
ABS JS
Gerry,
My km 14d is a 110 volt 2000 degree oven but it has no trouble holding to within +_3 DEGREES. I just got a km45d with 2400 degree coils in it. I have only used it twice so far and it has held 1550 and 1475 degrees at +_2 degrees for each temperature. I have not heated it over 1550 degrees so far.
