Paragon Jewelry Kiln Mods
So I purchased a small Paragon Jewelry Kiln, model E9C, and have tested it out and it does the job for getting the 1080/5160 I've got up to temperature for heat treating so I'm super stoked!
I've contacted Auber and here was their recommendations for what I'm looking to use it for:
"Basically you need a PID controller, a thermocouple, a SSR with a heat sink. The specs on this page noted that this kiln has 1300 Watt heating element, so you need a 25A SSR and a 25A heat sink. For thermocouple, you can consider WRNK-191 or TC-K-KLN.
Since you may need the ramp and soak function in the future, it's better to go with SYL-2352P.
These are parts that needs to be assembled together. You may also need an enclosure, a buzzer/indicator, and switches. If you would like to consider a plug-n-play unit, this controller WS-1500F can be configured to meet your needs."
So I'm going to be using it for heat treating 1080/1084, 5160 and 80CRV2. Even though I don't need the ramp/soak feature I figured since it's only about $30 more for that PID as opposed to the other I'd just go with it and then maybe use it for a future project if I ever go that route.
There's a hole in the back of the unit right about dead center as far as the height and L/R goes that's maybe 1/4-5/16. Would that be an appropriate place for the thermocouple? And there's a peephole in the front that swings open, should I insulate that, or is it too small to matter?
So because the Paragon unit is simply a plug in and wait setup, I would like to build a stand alone box for the controls that the Paragon just plugs into if I can.
So my big questions are, are the recommendations from Auber's appropriate for my needs? I want to get the parts ordered today and just get them ready for when I'm ready to start. Is there anything else I will need as far as wiring goes to tie everything together? I really have minimal experience with electricity so have no idea what I'm doing here.
Thanks as always!
Josh
