Stacy E. Apelt - Bladesmith
ilmarinen - MODERATOR
Moderator
- Aug 20, 2004
Just a note on why two SSRs.
When you are using USA 220 voltage there are two hot lines. One SSR would indeed stop the current flow, but it won't de-energize the coils. Even though the coils would stop glowing, and the door interlock was open, anyone who touched the coils with a knife or tongs taking a blade out would be shocked ... or electrocuted.
Two SSRs disconnects the power from both ends of the coils. This is the only way a door interlock would be of any good on a USA 220 volt oven.
On the cost factor, I am with JT.
Yes, you can use the cheapest SSRs, TCs, kanthal, PID, etc. but you are building a piece of precision equipment. Just like in cooking - the better the quality of the ingredients, the better the quality of the dish.
You are unlikely to get an good quality 8 gauge type K TC for $10. Then you need TC wire, a TC connector block, etc. That is a lot more than $12.
I also would get a better PID than a $20-65 unit for a HT oven.
The coils are the engine of the oven, and the wire size and quality should be the best.
I would say a person with knowledge of HT ovens and good shop skills in metal work and welding could build a good unit for $500. A person who isn't as well skilled may not be able to build one at all.
