New to the board but I thought I'd ask you guys on what my options are.
I recently got my para-2 and right of the box noticed the blade was not as fluid in opening as on most of the vids I've seen. I knew that if I disassembled it, it would void the warranty but I went ahead anyway thinking I would just lube it and that's that.
Upon disassembling the knife I discovered that one of the bushings had slight dents in it. I removed the little pivot cylinder and noticed that there was a very tiny piece of metal sticking out where the bushing is rested on and where that cylinder sits on. I'm guessing its a little piece left over from the drilling or machining. I attached a pic and circled in red. The pics are crappy cellphone pics but hopefully you guys can make it out.
Anyway I shaved that little piece off with some 1500 grit paper and also ran the washer on the paper to maybe get rid of the slights bumps. From the looks of it though it does not look perfectly flat like the other one. I lubed the knife and put it back together but it doesn't seem much better. There is side to side blade play and the only way to eliminate that would be to tighten the screws to a point where it is difficult to get the blade out.
Oh and if things weren't already crappy enough the blade is not centered and I had noticed that from opening the package but thought I'd get it right by playing with the screws. It sucks to have come across one that leaves you so disappointed when there are so many good reviews on this knife.
Let me know what you guys think and where I should take it from here.
Thanks,
Chris
Thanks,
Chris
