Paramilitary 2 Question
I found this blue sprint run Para 2 surfing Google, so no idea about this one. However, the blue is deeper than what I'm used to seeing. I'm assuming it was dyed to make the blue deeper and darker somehow? If so, how was this done? Instructions would be welcome.
I agree with Scurvy092. It looks like the it's just the photo. Looks a little underexposed and the white balance is off.
LB
Here's a corrected copy of the same image. I adjusted the exposure up 1/2 stop and applied a cooling filter to bring the white balance back from the warm/yellow side.
LB
Looks the same to me. Interestingly, other pictures of this knife seem to show the correct color.
I think it's the yellowish lighting as well(incandescent bulb maybe), along with the reflection from the blade which made the picture darker.
Here's my fixed up version:
If you did want to dye it, I believe people use Rit Dye.
I remember when the blue Skyline came out there were pictures showing it go from smurf blue to dark blue.
Rit dye works very well on frn, g10 can be a little tougher, sometimes you end up with a shade you were not expecting. A lot of it has to do with whatever color you are starting with along with the dye and your intended result.
It can help to do a google images and youtube search on the combo you are considering to see if someone has done it before you.
Did a bit of digging and found one of the S35VN Para 2's that had been Rit Dyed. Not sure the exact mix of brown that was used, but came out looking like a milk chocolate bar. Seems like keeping the same general color and simply taking it darker works well.
It's just how the photo looks. A lot of colors can be hard to pick up(blue can look darker or even black, Orange can look pink, pink can look orange, Purple can look brown, etc) so it turned out a darker color.
