- Feb 15, 1999
I know that I promised BBBB Beaver and someone else. But I forgot who, so I'll post it here.
PARTS LISTING
SUPPLIER PART# DISCRIPTION COMMENTS
NORTHERN 1053-C161 BARNES 2 STAGE PUMP -11GPM
2010-C161 PRINCE STANDARD 4-WAY CONTROL VALVE
4051-C161 7 GALLONS HYRAULIC OIL TANK MUST CLEAN THE INSIDE WELL
4022-C161 RETURN LINE FILTER
4010-C161 SUCTION STRIANER THIS GOES INTO THE TANK
FITTINGS AND HOSES YOU WILL NEED 3 HI- PRESSURE HOSES AND LOW PRESSURE HOSE FOR THE RETURN.
53606-C161 GLYCERIN FILLED GAUGE 0-3000PSI
SURPLUS CENTER 10-1485 ELECTRIC MOTOR I USE A 3 HP AT 3250 RPMS
09 4954 HYDRAULIC CYLINDER I USE A 4 1/2" BORE X 8" STROKE WITH THE PUMP AND MOTOR SHOULD BE GENERATE ABOUT 24 TONS
If I ever build another one I would go with a minimum of a 5" cylinder.
PARTS LISTING
