A comparison between the HI Passaround #2 and my Russel Canada Belt Knife.
As you can see from all of the photos, these two knives are uncannily similar to each other.
Once out of the sheath you can really see just how alike they are. In the above photo the HI is the one on the top.
One of the most notable differences is the HI's convex edge does not have a delineating line like the Russel's flat grind.
Surprisingly enough the spine on the HI is just slightly smaller than that on my Russel. Usually the HI knives have a noticeably larger spine profile. the HI is on the bottom in this photo.
The blade itself is slightly larger than my Russell. The nose of the blade was also shaped a bit differently with my Russell being more pointed than the HI.
This was supposed to be an edge-on view with an attempt to show that the HI blade is not sharpened next to the grip, unlike my Russell which is sharpened the entire length of the blade. Not sure if this was purposeful or not.
These views show the difference in the sheaths. As stated earlier in this thread, the sheath is not to be desired. The retaining strap is inefficient and actually does nothing to retain the knife in the sheath. It quite easily slips out of the sheath if the knife is inverted and there is ANY jarring movement. I much prefer my Russell's sheath and would love to see WildmanH replicate this type of sheath for this knife.
I found this knife to be a joy to use in handability. It fit into the hand quite comfortably and felt like a natural extension of the hand. This is not a heavy hitting type of knife but is instead a great utility design which lends itself equally well to such chores as skinning, cutting rope, cutting your meal, or even some whittling if you are a mind to.
I did not attempt to sharpen this blade as I am not really setup to sharpen a convex edge very well. It came to me sharp (except for the first 1/2" near the grip) and worked fine for cutting light duty work around the house. Hopefully I did not dull it to much before I sent it out to WildmanH!
I would consider buying this design from HI if I were in need of a general purpose utility knife for around the house or campsite. It is a definite proven design that lends itself nicely to the task at hand!
Thanks for the opportunity to work with this blade. It was enjoyable!
Jack
