- Feb 28, 2006
Hi Guys,
Very interesting discussion, What if rather than drilling through and peening, you actually threaded and tapped and screwed your bezel on a rod in place (maybe with a little locktite or something)? The The peening might be problematic for two reasons. Peening inside of the ring isn't going to give much room to work, either to peen or counter sink a hole. The other prob would be for your CZ. They don't like lots of pounding (it would be on the opposite side of hammering your rivet). Or would you trivet your finding prior to setting your CZ?
While you're at it, I don't believe the CZ will hold up to the heat for blackening the Ti if the Ti needs to glow bright red to turn black. In fact, your silver setting wouldn't make it through either. Maybe(?) white gold would, which might be a better choice than silver.
Also, are you locked in on the bezel cup idea? The CZ would likely be more brilliant in a pronged setting, which you could purchase in sterling or white gold, and solder to your rod. But it sounds like you have a look you're after, more like the stone flush mounted in the Ti. If that's the case, you might want to look into getting an appripriately sized piece of white gold or silver tube, You could set your CZ right down into it by drilling a seat with your stone setting burr. (Make sure to fab your rod end prior to setting the CZ.) You could than drill your seat in the Ti to the OD of the tube and a smaller hole for your rod.
Not sure if any of this makes sense or has any bearing. Hope you keep us posted on your experiments and share some pix.
All the best, Phil
All the best, Phil
