- Nov 28, 2012
If you want a fast forced patina, this works great:
If you want a natural patina - get some apples. Use the knife to cut up an apple. Leave the knife with the apple juice on the blade while you eat the apple. Then go wash and dry your knife after use. Repeat the process over several days. I call this the "take an apple with you to work for lunch" approach.
I prefer the look you get from just using the knife to eat apples over a period of time, personally.
I generally don't like having a patina on my CV knives so I polish the blades every so often to keep them shiny. I am not a fanatic about it so they generally end up with a light gray but shiny look to them over time.
- Degrease/wash your blade with dishwashing soap and water and dry it.
- Find a small, microwave safe glass. Fill it with white vinegar to the depth that if you put your knife blade in it, point down, that the vinegar would stop just short of the bolsters.
- Microwave the vinegar to just before it starts to boil. Take the hot glass of vinegar out of the microwave. Holding the knife by the handle, dip the blade into the hot vinegar until is is just short of the bolster. The blade will start to sizzle like an alka-seltzer. Hold it in there for about 20 seconds. Take the blade out, it will be mostly black. Wipe it off with a paper towel. A lot of the black will come off. Repeat the dip and wipe if you like. You can re-heat the vinegar if you want to.
- When you are done, wash off the knife and make sure you rinse it off well around the joint. Dry thoroughly and use some oil on the pivot. Spread a little oil on the blade and wipe off excess.
