Use a Sharpie marker and FC etchant. You can put whales on a blade or write your name. Remember, the part covered by the ink is the part that is not etched and will stand a bit higher. Polish the blade first, clean very well with acetone then with denatured alcohol. Apply the resist (Sharpie) and etch in 30-50% FC . Remove every couple of minutes and see how the etch is doing. Practise on a piece of HARDENED steel ( the type your blade will be) first to get an idea of the time required. To test the etch time do a test strip. On a piece of 2X6" , polished,hardened steel, write your name about six times about one inch apart:
STACY APELT
STACY APELT
STACY APELT
ETC.
Start with a two minute etch. Remove the strip and rinse. Using a Sharpie marker, black out the top name area completely. Put it back for two more minutes. Repeat, adding more time as seems fit for each blackout (write the times down!). Once all names are etched to different amounts, rinse, clean with acetone, stop the etch with Windex and give the strip a good rub down with steel wool . You can see the different depths that the etch attained. Sand the strip with 400 and buff. The results will give you a target time for the type of etch you are looking for.
Stacy
