- Oct 16, 2001
All good. I really appreciate these threads.
John
John
I really look forward to seeing where this thread goes. Not to change it's direction because I too am always happy to see another maker taking a shot (stab?) at European medieval swords, but can I suggest that by the time of Chivalry pattern welded blades were pretty few and far between especially as we advance into the period? I don't know if your interests run that way but perhaps for a pattern welded piece Ian Pierces "Swords in the Viking Age" might be a bit more appropriate?
However that quibbling aside I certainly don't want to throw you off the track and was wondering if you might be willing to give us a hint as to which Oakeshott type you were thinking of creating?
Thanks for your comments, and suggesting that book. I can certainly use all the reference material I can get. I just reserved it at the library.
The style that appeals to me is something along the lines of Wheeler's Type VII, which was toward the end of the Viking era, if I'm not mistaken.
Circa 900 A.D., according to the book.
I'm far from an expert on swords, but I do know what I like.This is not going to be an exact historical replica, but rather I'll just be taking elements I like from various swords and mixing them up. So, sword purists beware.
Another title you might find interesting is Hilda Ellis-Davidson's The Sword in Anglo Saxon England.
Of course now that you roughly have the hilt form picked out you are going to have to take a look at Geibig's typology (also in the Pierce book) and pick a blade type.
I don't think that concept will necessarily offend sword purists. That is after all what Albion has done quite successfully with their production medieval swords. Of course their mixing and matching is historically plausible they aren't fitting 10th century hilts on 15th century blades or anything.
A couple of more questions if I might, recognizing that you may not have really thought through what you want to do yet. Do you intend to make the pommel with a two piece construction as were the originals? Are you planning on doing inlay work on blade or upper / lower guard? Were you planning on adding distal taper? A fuller?
Sorry if I'm asking too many questions, I just can't help remembering the fantastic cinqueda that was featured in blade magazine just recently (I cannot remember the makers name unfortunately.) Like yourself he was a knife maker that wanted to really push his own personal envelope and he was incredibly successful. Mostly with my questions I'm hoping to get the old wheels spinning a bit so that your idea turns out as happily.![]()
That's good, maybe someone out there will buy this one.![]()
Given my lack of skill at carving steel, I'll probably go with the two-piece pommel.
I'm undecided yet what material the guard and pommel will be. Could go with damascus, like many modern swordmakers are doing, or bronze.
I would like this too be wield-able, so I was planning on distal taper and fullers. The fullers will be ground in, both for the patterning effect and because I'm not equipped to forge them in.
Great pics, Phillip, and looking forward to how this WIP progresses. One of your early pictures peaked my curiousity. Don't know why I never thought of it before. Pardon my ignorance but when one welds the rebar to the bar and then heats it, why doesn't it separate? Is the welding temperature higher than the forging temperature?
Incidentally, I am really enjoying the knife you made for me!
Paul
You never know...![]()
Historically, that is the way they were done so I think you are following the right path. Typically most modern makers do a one piece pommel on Viking Style swords because their hilt components are cast and thus cheaper.
From a marketability standpoint I would suggest the damascus or even plain steel above the bronze. Historically speaking, bronze was very popular but for whatever reason in today's market steel seems to be the metal of choice for both hilt and scabbard fittings. For every scabbard I do in bronze I do 15 or more in steel.
I've got a name (I'll have to look it up when I get home) of a guy that builds these, if you have technical questions he may be able to help.
The kind of technical questions I have are pretty much about dimensions. Like, how wide should the guard and pommel be, and how thick? How thick should the blade be? How long should the handle be? Etc.
Thanks for your input and questions. They're helping me solidify things somewhat in my mind.
