PCB Echtant dilutions?
So I have been using PCB Echtant for Radio Shack(ferric chloride mostly) to acid wash my knives. I have a couple larger knives that I will be finishing up soon and don't have enough echtant to cover them. I was wondering if there was a simple solution I could dilute it in to give me "more" ferric chloride while still achieving the same results in the acid wash? If not I can just go and buy more from the shack next time I'm in town. Just curious if there was a better way? Thanks
Ben
Are you diluting the etchant at all? It is quite concentrated if not diluted. I use distilled water in my etchant, approx 5:1 water to acid.
Most use a 3:1 up to 5:1 ratio ( water to FC stock solution). For more delicate etching and hamon work, it is usually 10:1 up to 15:1.
When mixing the stock solution from dry powder, use caution.
Mix it outside and stay upwind. It gives off a chlorine gas when you first mix it. It also can get very hot while mixing. Add the powder slowly to the water. Don't mix it in a thin plastic jug ( milk jug)...it might melt. Mix it in a heavy plastic bucket, like a drywall bucket. When cooled down, pour into a plastic storage container and wash out the mix pot.
FC should be mixed to make a stock solution. You add one pound to one quart or four pounds to a gallon of water. Distilled water is best, but any water that is not full of minerals (I use bottled water) is fine. Let it sit for a couple days before using it. Dilute the working solution from this stock . Three parts water to one part stock is what most folks use.
If you are just making up one gallon, skip the stock solution, and add one pound FC powder to a gallon of water. If making up a larger batch, one gallon of stock solution is easier to store than four gallons of working solution.
Again - Mix outdoors and don't breath the fumes when it is dissolving. Wearing gloves and a face shield, is a good practice.
4# of powdered FC sells for about $30 on eBay. It will mix a gallon of stock which will make four gallons of etching solution. Immensely cheaper than Radio Shack or other pre-mixed suppliers.
So I can just add distilled water or bottled water to my solution and I'll be good? Wow that makes things very simple! Sorry for the stupid question appreciate the speedy answer!
Ben
I just etched a large damascus blade using a 3:1 ratio of water to ferric chloride pcb solution (Radio Shack). Came out nearly black. Surface prep was 400 and 600 wet or dry and a good degreasing. I may try some 0000 steel wool and oil to knock it back a bit. I will definitely try a 4:1 dilution next time. Kind of took me by surprise. It is much faster than parkerizing which I have done a fair bit of. I kind of wish I still had that set up because I think a zinc park would have been closer to what I wanted.
The steel is purportedly1080 and 15N20 btw.
Work it with some steel wool and oil a bit and it should lighten up. If needed, wet sand with 800 grit paper and re-etch for a shorter etch.
