Peanut frustration
I spent another hour tonight on the Sharpmaker diamond rods to even out one side that I checked with black marker. Went to the course and fine and still ain't cutting. This knife was brand new and looking like an old 100 year old knife soon.
Case steel can be pretty finicky.
Once I get a burr on both sides I go to almost no pressure on the stones.
It doesn’t take much pressure to remove steel from such a small blade.
Also I never used diamond plates on Case steel, neither CV or the stainless, they are way too aggressive.
Sorry to hear you are having problems with your Peanuts. Sometimes you need to sharpen and use a knife a few times before you get to the good steel and the sharpening and edge holding improve. It was like that on my peanut.
Let us know how the sharpening goes!
The key with using a diamond hone on small knives in such steel is to downsize the grit used and the pressure applied, for the task. Scale the grit, pressure and number of passes to the job at hand, i.e., blade size, thickness, steel type. A Fine (600) diamond hone can do anything that's needed, from reprofiling to touching up, with much less effort (pressure and number of passes). Anything coarser than the 600 diamond would be overkill, unless the blade is large and/or very thick, and it leaves the edge on a small blade too ragged to be very useful, without more refinement at a finer grit. And for touching up, just a handful of very light passes (maybe 3 - 10) per side, on a Fine or EF diamond hone, can do all that's needed.
Many will overgrind with a diamond hone, counting a certain number of passes or going a given length of time before assuming it's 'done'. Or, they'll start at too-coarse a grit. Since a diamond hone can work at 2X - 3X the pace of other stones at a similar grit, it's important to watch closely for the apex with every pass, which will come a lot faster, especially on a very small blade like the Peanut's. On a blade that small, sharpening with a bench-sized (6"/8") 'Fine' diamond hone could get it there in perhaps 5 passes or less per side, completely resetting the bevels.
So, 'too aggressive' comes down to either (1) too-coarse a grit for the job, or (2) grinding too long or with too much pressure for the steel type/thickness/hardness being sharpened. The abrasive type, by itself, doesn't matter as much, so long as it's hard enough to cut the steel being sharpened. The extreme hardness of diamond for cutting these steels is a good thing, because it means it cuts the steel very cleanly and effortlessly at a light touch (this is all-important), which minimizes burring.
I'm not real crazy about rod-type diamond hones, as many of them, including the SM's diamond rods, are maybe a little too coarse for small(ish) blades in simple steels. The SM's diamond rods have been characterized at around ~ 400-grit. If using them, I'd limit such work to only the flats of triangular rods, as the corners focus too much pressure to be managed easily, with diamond in particular. I set my lowest-grit threshold for such small blades & steels at something equivalent to DMT's Fine (600) hone, which leaves the edge much cleaner & sharper, with less work.
Try checking the edge with a loupe to see your progress. I hope you find a solution. The peanut is a great little knife.
Nathan
I'm thinking the problems may stem from over doing it. Try lighter pressure and fewer passes.
Not putting Case down here, one of my two favorite brands to collect and use (old & new) but you can step out (cheaply) by adding an old Schrade USA "peanut" to your stable of knives. These Old Timers were made with a very easy to sharpen 1095 steel and lay flatter in the pocket than the Case due to the flat, sawcut Delrin handles - there is a one blade version - Clip (12OT) and a two blade version - Clip & Pen (72OT). Worth scouting around online for one. OH
