- Aug 12, 2002
OK, first attempt at peening pins today, had the little set of 4 woodworking knives from TKS, and was jsut making them for myselves(and to see how homemade micarta worked out, not as well as I wanted). Anyways, decided instead of just expoxying pins this time, I'd peen them. Had already epoxied on both scales, and epoxy was dry(this may be my problem). Went to peen them, and at least twice, had problems with pin bending some. FIrst wasn't too bad, but second time I managed to break epoxy and shift slab a bit off center.
I know first thing I need to do is use shorter pins, as I left them a bit too long, and so it was puttting too much leverage sidewise on the scales. But is there any other tips, both to keep the pins straight, and to keep from breaking epoxy(which I guess are two sides of same coin)?
THat being said, these scales are all on there VERY well now. THings aren't moving at all, and won't unless I cut out the pins.
